Re: Cub ignition
Posted by John T on October 27, 2011 at 11:13:44 from (173.243.181.15):
In Reply to: Cub ignition posted by RGMartin on October 27, 2011 at 08:01:19:
Sure you can, the other fine gents have shown how to wire it, youre just using the points in the mag to cause the external coil to conduct then interrupt its current flow. HOWEVER remember that mag only has two timings, static start timing and advance run timing, NOT an RPM based variable advance like a real distributor coil ignition, and as such wont perform quite as well. One problem can be if a dude takes a small Cub and converts it to 12 volt the starter may spin her over so fast its trying to start at the non retarded (run time advance) timing cauasng kick back and starter problems.
John T
