MD compression #'s
Posted by jfrankhash on October 27, 2011 at 17:11:07 from (67.142.173.20):
Still working on "starting problems" on gas side of my 52 MD. Checked the compression #'s on the gas side and got these results:
#1 100 psi
#2 112 psi
#3 80 psi !!!
#4 90 psi !!
Would this be enough to cause to only "SPUTTER"
whentrying to start?
Any suggestions?
Thanks, John
