Re: H Front Bolster OIl Seal
Posted by Bob M on October 27, 2011 at 17:32:08 from (69.207.87.100):
In Reply to: H Front Bolster OIl Seal posted by George Rausch on October 27, 2011 at 16:49:55:
I made a "pusher" tool from piece of hickory rake handle. Turned one end a bit less than the seal OD, then turned a step to match the seal ID. Slipped the seal over the the turned end then used a hammer on the opposite end to tap the seal into place.
Note: Even with a new seal in place the steering box on mine still seeped oil when refilled (suspect a slight wear groove in the bolster pivot shaft). I wound up packing the box solid with good chassis grease - no more leaking oil!
