Try using a diesel pulse timer for pinpoint setting on the timing, it looks at the fuel pulse to #1 cyl, twist the injection pump as required. Also you said some wiring was done, did you keep the original glow plug harness set up. It should split between the 6 cyls, if you ran it from one end or the other the glow plugs will not heat even. ie if #6 is first in line of the daisy chain it would get the most amps and be hottest and 5 thru 1 would be progressively cooler or not heat up at all in the prescribed 1 min.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
