Re: IH #60 plow
Posted by Mike1972chev on October 28, 2011 at 08:14:12 from (75.149.81.173):
In Reply to: IH #60 plow posted by henryv11 on October 28, 2011 at 06:23:28:
If it is like my #16(Which I think it is???)There is a big"washer" set behind the bearing race that sits on a ledge in the hub.It is very hard to punch out the bearing race without desroying that washer.I had one h#&l of a time doing mine!
If that washer was notched on both sides,it would be easier to drive them out.If you hit directly on the washer,it will bend it!
You dont wanna tear up that washer!Maybe others will "chime in" !
