Posted by glennster on October 28, 2011 at 10:16:45 from (76.224.4.21):
In Reply to: cub missing posted by Skipster on October 28, 2011 at 09:24:46:
if the cam gears are off, it will run bad all the time. i looked back a couple pages to see what else was going on with your cub, and i see the water in the exhaust post. if it runs good at times, then doesnt, i would re examine the ignition system and fuel system. disconnect fuel line from carb and let it run in a can for a few minutes to be sure you have good delivery and no sediment plugging stuff up. you have a new carb, so hopefully that is ok. do you have a mag or distributor ignition? recheck cap and rotor for damage, also re-check points and condenser. then wiggle distributor shaft side to side and check for worn bearings in the distributor. clean up all the electrical terminals if it is a distributor ignition. start at the dist and work back thru the coil, then to the ignition switch,then on to the battery power. try also running with the air cleaner tube removed from the carb, in case that is plugged up.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
