Re: cub missing
Posted by Skipster on October 28, 2011 at 12:02:37 from (76.112.18.13):
In Reply to: cub missing posted by Skipster on October 28, 2011 at 09:24:46:
Thanks for the replies.I think since the plugs fire every hit with blue spark it should go.Iv e tried to time it with aligning #1 on compression stroke, but something is still wrong.My manual says there should be 2 marks on the pulley tdc and 16deg btdc, but I only see 1 mark.Thats where I ve been lining it up. But from there I ve twisted it each direction.I ve replaced several parts but keep coming back to the good spark at plugs and gas at the carb, with good compression.I ve been working at it over a month now and just can t seem to come up with the right answer. I m almost ready to haul it to the dealer and that will be a hard pill to swallow. Dick
