Re: m+w 9 speed
Posted by Roger on August 26, 2000 at 19:36:05 from (209.100.170.185):
In Reply to: m+w 9 speed posted by kss on August 25, 2000 at 20:45:55:
On the MD I have with the 9 speed transmission, the overdrive is shifted with a lever. The others I have seen also have a lever. Does your's have some kind of a cable? On mine, the lever is mounted on the same bracket with the diesel/gas lever with a rod connecting the lever to the lever on the left side of the transmission. Roger
Post A Followup
: Re: Re: m+w 9 speed
