Re: 40 B runs then dies
Posted by El Toro on October 28, 2011 at 14:43:58 from (108.40.22.75):
In Reply to: 40 B runs then dies posted by scott strother on October 28, 2011 at 14:35:14:
Make sure you're getting gas to the carburetor. Check the flow from the tank by disconnecting the gas line at the carb. Hold a clean container to catch the gas. If there's a full stream of gas from the tank remove the tube fitting where your gas line connects. Look for a screen behind that fitting that be plugged with dirt or rust. If it's looks clean you probably need to remove the carburetor and soak it in carb cleaner and blow out the jets. Check your float level. Hal
