Re: super c crank pulley
Posted by jonathan mirgon on March 12, 2009 at 11:09:37 from (4.225.102.36):
In Reply to: super c crank pulley posted by jonathan mirgon on March 12, 2009 at 04:19:07:
There is still clearance to allow it to go on further, I am unsure how well the belts would line up as is because it is still sitting on the engine stand. I suppose I will go with the all thread press set up, And hope I dont damage the crank and or the thrust bearing. It sure would make life easier if someone came up with an aftermarket pulley that utilized a set screw and then the proper weight cast into the pulley on the opposite side to keep it balanced. This is the seconed one I have rebuilt and this pulley is easily the worst part of the job. Thanks for your replies.
