Re: 560 carb issue
Posted by MartinD on October 29, 2011 at 06:41:36 from (209.212.137.150):
In Reply to: 560 carb issue posted by MartinD on October 29, 2011 at 06:11:25:
We have had the tractor running before by feeding it gas. I probably bone headed something in the rebuild.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
