Re: Farmall C Rear Axle Gear Problem
Posted by BoonvilleKid on October 29, 2011 at 08:04:08 from (24.206.167.119):
In Reply to: Re: Farmall C Rear Axle Gear Problem posted by 460anger on October 28, 2011 at 18:18:27:
I'm really curious as to what would cause these bolts to come out. The only thing I can think of is that the brake bands were worn down so far that even the rivets were gone. Would this have set up a vibration on that shaft or somehow had something to do with the bolts backing out?
I worked a little last night on removing the lid. No problem on the lid bolts but getting the bolts out of the tool box and steering pedestal housing was a nightmare.
I'm convinced that I wouldn't be able to do any good even if I could access it from the back. I can't imagine my being able to get that first bolt started while holding the washer in place - all with one hand that I can't see.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
