Re: 560 carb issue
Posted by redroundhead on October 29, 2011 at 08:13:28 from (70.14.11.48):
In Reply to: 560 carb issue posted by MartinD on October 29, 2011 at 06:11:25:
Is the manifold gasket there? As was stated,check for suction,. A leaky gasket = no suction. Is cranking speed to spec.? Slow crank = no suction/low compression. Is the valve lash correct? A partially open valve will do the aforementioned issues as well.
Best of luck!
