Posted by George Rausch on October 29, 2011 at 15:13:21 from (64.85.216.186):
For what it's worth, I think I may have fixed my wobble. [DISCLAIMER= Try this at your own risk. I worry about the steering shaft cracking.] First, I serviced the wheel bearings, cleaned and lubed them, tightened up the bearings, made them smooth as butter. Next, I finally figured that my wobble was the worm gear has too much wear and slop, where it meshes with the circle gear. I noticed the mid-teeth of the worm gear were smaller thickness than the outer teeth. I ground off 1/4" of the rear of the worm gear teeth, and built a 1/4" spacer to fit between the bearing and the front of the worm gear. Stuck her all back together; this idea shifts the worm gear 1/4" to the rear. Man, does it work great. Drove all over the place, and drove a few miles into town, gassed her up, went to the car wash, miles back home, and it drives smooth, like your car. Just a very slight steering correction ever so often, just like your car. My worry is that the worm gear shaft has been ground-down, a little, and might fatigue crack. If it does I'll let everydoby know. But MAN what a difference!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
