Re: new Farmall H for me!
Posted by The Red on August 27, 2000 at 02:48:28 from (12.75.196.51):
In Reply to: new Farmall H for me! posted by Pete in PA on August 26, 2000 at 15:36:01:
Congrats on the H. If the generator and top mounted voltage regulator are hooked up, remove the cover on the voltage regulator and make sure the points are closed when the engine is running. If not, you can adjust the spring tension. If the points are closed and still no charge, you will have to get the generator and regulator tested to see what needs repaired or replaced.
Post A Followup
: Re: Re: new Farmall H for me!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
