Posted by D Slater on October 29, 2011 at 19:12:17 from (184.15.3.93):
In Reply to: Re: 1950 M posted by janicholson on October 29, 2011 at 16:58:56:
Jim are you thinking of another engine? At the row of bolt holes across the back of the pan theres a steel plate. Long bolts go through the plate and into the block. Install on each side of the center rear oil pan bolt hole, or each side of the stud if its still in the plate.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
