Re: Farmall C Rear Axle Gear Problem
Posted by Owen Aaland on October 29, 2011 at 20:55:36 from (216.47.32.147):
In Reply to: Farmall C Rear Axle Gear Problem posted by BoonvilleKid on October 27, 2011 at 18:04:13:
The bolts came out because they were loose. They became loose as the bull gear and axle wear. The bull gear is a slip fit on the axle so there is some movement between it and the axle. Over 50+ years the wear was enough to release the tension on the bolts.
Later/replacement axles use a snap ring instead of the bolts and washer.
