Re: Changing Front Crankshaft Seal
Posted by El Toro on October 30, 2011 at 04:11:07 from (108.40.22.75):
In Reply to: Re: Changing Front Crankshaft Seal posted by Stevie J. Mote on October 29, 2011 at 20:24:02:
When I did an A I unbolted the front wheels from the engine block and rolled the steering wheel and wheels out from under the tractor. You need to support the engine well. I think I removed the radiator too. You probably will need a good puller and a big split bearing separator to remove the damper pulley. Don't pull from the outer edges of the pulley as they're easily broken. You need to check the surface of the pulley hub for a worn groove from the old seal. They have speedi-sleeve's to cover that surface available at Napa and the seal too. Hal
