Re: Fender Gasket's?
Posted by Stephen McCoy on October 30, 2011 at 07:11:34 from (173.27.210.76):
In Reply to: Fender Gasket's? posted by Livin the Dream on October 30, 2011 at 06:37:27:
I restored my B a couple years ago and don't recall any gasket like material between the fender and the casting. I'm not saying there isn't one, I just don't remember seeing one on mine.
If you really feel one is necessary, let's say to dampen vibrations since it wouldn't serve any purpose as far as preventing leakage, you could make one from thin card-stock by tracing the pattern from the fender.
It might be easier to use 3/8" thick foam insulation, the kind with the double stick tape on one side used to help seal doors, and attach it to the casting to isolate the fender from it.
I hope all my rambling made some sense and can help.
This post was edited by Stephen McCoy at 07:12:57 10/30/11 4 times.
