Re: Re: To Settle an Argument
Posted by JRM on August 27, 2000 at 05:32:10 from (64.12.105.188):
In Reply to: Re: To Settle an Argument posted by James Otoupal on August 26, 2000 at 21:04:05:
I agree. Amps is the "push". We use dual 12 volt batteries on snow plow setups, usually a pair of 900+ amp batteries for approximately 1800 to 2000 total amps. A single 650 amp, 12 volt battery will start the truck fine, but add snow plows, salt spreaders, lights, etc. and the 650 falls far short of doing the job. Both battery setups will measure only 12 volts on the volt meter, while the dual setup is almost 3 times the amps.
Post A Followup
: Re: Re: Re: To Settle an Argument
