Re: Crankshaft on '44 H
Posted by CGtractor on October 30, 2011 at 11:37:57 from (198.231.23.240):
In Reply to: Crankshaft on '44 H posted by Jim Paterson on October 30, 2011 at 07:08:49:
One of the easiest ways to remove keys is with side cutters. Grip the end of the key with the cutting edge of side cutters as close to the pliers pivot point as possible. With a firm grip on key, lift up on side cutters, prying the key out of it"s slot.
