Re: 666 Hydraulics
Posted by Brian Dan on October 30, 2011 at 18:25:12 from (71.10.108.51):
In Reply to: 666 Hydraulics posted by Steve 101 on October 30, 2011 at 17:29:02:
My good friend has a 656 with the same problem.
Under the seat or rock shaft there is a low pressure hydraulic tube the maybe cracked or broken off. This has happened twice with his 656.
