Re: H engine valve lash adjustment
Posted by luv2wrench on October 30, 2011 at 19:44:47 from (75.226.246.8):
In Reply to: Re: H engine valve lash adjustment posted by James Williams on October 30, 2011 at 11:50:23:
just cuz your in the corn crib or what?? Yeah the approch may work for you for awhile. I can see not using a feeler guage, but torque wrench? Your elbow isn't the same everytime. I set clutch pack clearences all the time by sight and feel. But torque? Helps to have it even steven. I know you can torque an entire H together with a 3/8 ratchet and it will run but come on.
