Re: Changing coolant in 460 Farmall, easy job for a novice?
Posted by mike paulson on October 31, 2011 at 01:58:24 from (98.15.187.200):
In Reply to: Changing coolant in 460 Farmall, easy job for a novice? posted by Matt (NEIA) on October 31, 2011 at 00:41:13:
yea just open petcock at bottom of radiator and drain into a bucket. then get either premixed or U mix it coolant. if you get the kind you gotta mix 50/50 is good in most climates, if you live far north the 2/3rds coolant and 1/3rd water.
just refill, run till hot, let it cool for a few hours and recheck level. should be about 2in from top....oh, you can use the standard green coolant.
