Re: H Leaking OIl
Posted by Zachary Hoyt on October 31, 2011 at 04:44:52 from (184.12.70.149):
In Reply to: H Leaking OIl posted by George Rausch on October 31, 2011 at 03:37:38:
It's not too bad, first you take the belly pump drive shaft out, and the belly pump too if you want more room. Then take out the four tapered bolts in the driveshaft and take that plate out. Then you can remove the bolt in the center and slide the collar off and remove the key and then the seal retainer can be unbolted and removed. It is not a really quick job but it's not bad.
Zach
