Re: firing system switch?
Posted by CNKS on October 31, 2011 at 07:10:30 from (216.144.104.128):
In Reply to: firing system switch? posted by kennell on October 31, 2011 at 06:06:01:
I tend to agree with mkirsch -- and it sounds more like carburator trouble -- you really need an operators manual that explains what to do. As a start put it at WOT with the engine warm, turn the main jet adjustment screw in until it sputters, then out until smooth. Adjust the idle mixture until smooth. Repeat both until it accelerates smoothly, if not your carb needs to be overhauled, and there is a small chance that it is an ignition problem.
