[What would happen if I changed it to a positive ground?]-You would straight away blow the diodes in the alternator and let all the smoke out-LEAVE IT AT NEGATIVE ground
[I did not change the fields in the starter]-Not required-starter is a series wound motor and will rotate in the same direction whether + or -ve ground
I have it neg. ground but I went to IH and they say positive ground on the 12 volt gas. Is that my problem?-NO YOU-PRESUMABLY-correctly changed it to Negative ground to fit the Alternator
I would guess your problem is a bad connection, somewhere in the wiring from the +ve battery terminal to the starter solenoid operating coil connection [Sometimes marked S]-you say there is no solenoid "click" when it fails. So, whatever you do, don't change the Polarity and post back with the results of the checking for +12 volts at the solenoid S terminal on an attempted start. Make sure you are not going to be run over etc if it does start
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
