Re: need help with farmall 400
Posted by D Slater on October 31, 2011 at 08:19:13 from (184.15.3.93):
In Reply to: need help with farmall 400 posted by John Seasly on October 31, 2011 at 06:47:11:
Some things to try when it doesn't start. If sure the battery cables and connections are okay and you have the original type starter switch on top of the starter. Test to see if power is on the small terminal when switch is turned to start. Or making sure the tractor is out of gear, jump power from the battery cable terminal to the small one. If that doesnt crank it run a jumper cable from positive or starter battery cable to starter post or strap going to the post, this would bypass the starter switch. Small terminal no power = bad ignition switch or a bad connection from or to the switches. Bypass starter switch and starter works = bad starter switch. Jumper cables from positive battery terminal to starter post and the negative to good ground = bad starter or bad battery.
If tractor has a later type starter switch with 2 small terminals the small terminal with a S will energize the switch.
