Posted by bc on October 31, 2011 at 08:22:03 from (68.92.138.225):
In Reply to: firing system switch? posted by kennell on October 31, 2011 at 06:06:01:
Sounds to me more like a fuel delivery problem with rust or floating crud in the tank. You should be able to pull the fuel line and and run a few gallons into a can with no restrictions in flow. Remember these gravity feed tractor carbs don't have fuel pumps or fuel injectors like a car carb.
Is there any rust or crud in your sediment bowl?
Cleaning the carb will only be a short term fix if you don't fix the original problem as the carb will get plugged up again. Don't ask me how I know. If rust is a problem, there are a number of short term fixes which can be found through searches here.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
