Posted by Shawn MacAnanny on October 31, 2011 at 10:38:46 from (75.105.200.204):
Well i bought 15 gal of xtreme hydraulic/transmission fluid today (they were on sale for $33/5g) said its a replacement for ihc hytrans. i also got my manual to see how to adjust disassemble the draft and drop valves etc should it come to that. I also ordered the allied precision larger filter kit and an extra filter. i will be draining everything later today and removing old filter and inspecting everything. manual says to crank over with coil wire off to pump extra fluid out too.
Hopefully i will get lucky and new fluid and filter will fix problem, if not i will remove draft and cylinder plate and start working there. never messed with one before so hopefully i wont mess it up.
also the manual said in the fluid capacities chart 2qts in the pto clutch. Is this area separate from the transmission, hydraulics and power steering or is it all a common resivoir? pto works fine although i havent hooked anything to it but i would like to get fresh fluids everywhere i can before i start using this tractor and trying to locate problems.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
