Re: firing system switch?
Posted by mkirsch on October 31, 2011 at 12:07:15 from (64.80.110.75):
In Reply to: firing system switch? posted by kennell on October 31, 2011 at 06:06:01:
Ah good.
What was with the clueless act at the beginning? All of a sudden you went from calling it a "firing system" to being able to recognize a faulty set of points in the distributor.
When asking questions more information helps. Calling it a distributor, and the fact that you did an ignition tuneup would've been useful at the beginning, and would've probably kept me from treating you like a greenhorn.
BTW, the distributor advance curves are different from a C to an M. If you swapped them out the M wouldn't run right, and neither would the C.
