Re: farmall m power steering
Posted by IAtractorKid on October 31, 2011 at 12:32:06 from (173.26.100.72):
In Reply to: Re: farmall m power steering posted by musky11 on October 31, 2011 at 10:08:25:
third party image
This would be the alternative pump mounted on the side of the governor with the reservoir mounted higher. With this setup the pump is clearly visible and you need the extra crankshaft pulley.
The other setup I showed just uses a longer belt between the PS pump, water pump and generator/alternator.
