Re: H Leaking OIl
Posted by George Rausch on October 31, 2011 at 14:48:02 from (64.85.215.70):
In Reply to: H Leaking OIl posted by George Rausch on October 31, 2011 at 03:37:38:
Zachary; Got down to the bolt holding the two-bolt clamp on, and it does not come out. I cannot get it to loosen up. I'm creeping the tractor backwards 1/8" at a time. It is right-hand threads, right? Nothing tricky about it?
Thanks ahead of time. It is a straight-forward job after all.
