Re: Farmall M Questions
Posted by sflem849 on October 31, 2011 at 20:07:18 from (69.197.84.39):
In Reply to: Farmall M Questions posted by 41106 on October 31, 2011 at 08:10:34:
lblocks picture shows two way hyd, not live hyd. You do this so you get downpressure.
mkirsh's picture is a little tricky because it actually shows a factory live hyd res and a belly pump used as a res, but you get the picture. You could also build a res and put it in place of the belly pump or below the gas tank or ???
Does he have to replace the front timing cover and gear if he uses the live pump?
