Posted by Janicholson on October 31, 2011 at 20:17:13 from (67.72.98.45):
In Reply to: Super A Questions posted by Badger08 on October 31, 2011 at 18:20:23:
Mufflers are available from CaseIH or tractor stores. The Stanley Brand seem to be OK but not long lasting and not true sound. Stainless Steel Mufflers are pricy but way long lasting. If it needs a Water pump, and is not equipped with one. you will need more than just a pump, there is a block adapter, and belt as well as other components. Steering box wear is in three places. Bearing on the end of the worm (check shaft for in and out as it is turned, None should happen) Sector to worm. Could require a new gear or both of them if toast. Third is the connection under the box where the arm attaches. There are two types. Woodruff Key, and square taper. Both give problems and are a likely issue. The Key can be ground or milled bigger and replaced with the next size. the square shank can be built up and refiled to fit again, or a new arm can be used to fix it if the shaft is OK. Good luck and congratulations on keeping it in action. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
