Posted by gene bender on November 01, 2011 at 03:26:16 from (67.55.226.244):
In Reply to: Super A Questions posted by Badger08 on October 31, 2011 at 18:20:23:
Water pump can be added all you need is a new pump with pulley and longer belt nothing more. Steering play can come from many places start with the tie rods then to the arm where it fastens to the steering sector then the rest of play if still there would be in repairing the steering sector as there are bushings a bearing and a keyed gear. To repait the steering play just mite require removing the whole assy from the tractor. You will not be able to get a original muffler like that one but new replacements are available for around 25 and if the tractor is kept inside out of weather will last many years. I have rebuilt several steering problems and no two are realy alike its sometimes a little play here and a little play there and it all ends up with too much play. You trasctors play doesent have anything with what gear you are in the play will be the same in any gear you just notice it when going faster. If you decide to go with the water pump when you have the rasiator off and removing the steering sector that would be the best time to add the water pump. Ive done it with out removing radiator but i do have tons of experience on working with these little tractors. good luck
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
