Re: farmall 706 parking brake
Posted by The tractor vet on November 01, 2011 at 08:33:32 from (75.19.123.11):
In Reply to: farmall 706 parking brake posted by Ted Klapperich on October 31, 2011 at 19:25:56:
well it all depends on what happened . IF it still has the old over center linkage then hopefully she is way out of adjustment. and it just jumped over the gear. BUT if it did not just jump over the gear and it took teeth off that gear then you are in for a lot of work . Tractor has to have a rear split and tires and wheels have to come off rock shaft housing needs to come off transmission coves have to come off and the list goes on as that gear will be the last out and first back in . Then when your done and before you put the top transmission cover on i would recommend that you install the new spring loaded park lock loc. Oh and always before you engage the park lock make sure that the transmission is IN neutral and your foot is OFF the clutch.
