Posted by Haas on November 01, 2011 at 12:50:58 from (75.216.248.78):
A while back, my I-6 got stuck in reverse. When in neutral, it was in reverse. The shifter seemed to move like it was in neutral, but I don't think it ever got as far as the 1st/reverse shifter fork. If you put in any other gear, then it was in two gears and would not go anywhere. I recently got around to the job of taking the shift lever out to investigate. Gettin the shifter pin out and pulling the shift lever out was easier than I thought it would be. Stuck a screw driver in there and lined the rails back up. The end of the shifter lever looked ok to me, but the cross pin seemed to have a lot of wear. I made a new one from a 7/16 inch bolt which seemed to fit the hole in the shifter. But...the hole in the transmission cover that the pin goes through seems like a loose fit to me. Is there supposed to be a bushing there or is the hole wallowed out, or is a fairly loose fit there normal?? I put it back together and drove it around testing all the gears. Seems to work good now,(being careful while shifting gears) but do I need to do some more to tighten thinks up? And is the home made pin from a 7/16 grade 5 bolt going to be OK?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
