Re: H Transmission Oil Seal
Posted by Zachary Hoyt on November 01, 2011 at 15:08:27 from (184.12.70.149):
In Reply to: H Transmission Oil Seal posted by George Rausch on November 01, 2011 at 15:03:16:
Yes, it is keyed and it does slide right off. I've only had to take a couple apart and they both came pretty easily. If you have to you could take the 6 bolts out that hold the gear and shaft assembly and take the whole thing out where you can get at it better. You could probably put it in a press or even cut and crack the stuck collar off in the worst case. I can't remember if the input shaft has to come out first or not but it should be apparent once you get in there. Best of luck with it.
Zach
