Re: 6 volt Battery
Posted by Paul from MI on November 01, 2011 at 16:42:55 from (204.106.241.145):
In Reply to: 6 volt Battery posted by Todd Heck on November 01, 2011 at 16:21:42:
If you have electricity in the barn I would look at a battery heater. A little warmth really peps up a battery. Of course you could look into a block heater too. Actually a BN isn't a very big engine and should start fine on 6 volts unless it's really cold, way below zero. As others have said, with 6 volts the condition of all connections and having large enough cables is critical.
