Posted by Badger08 on November 01, 2011 at 18:44:11 from (8.24.104.131):
In Reply to: Super A Questions posted by Badger08 on October 31, 2011 at 18:20:23:
Thanks, I am glad to get the SA back, and back on the farm! Well the muffler is junk. It is rusted through on the bottom pipe and the top pipe coming out of the muffler. Not much left keeping it on, as even the pipe clamp has slid down coming in contact with the hood. I found a NOS muffler on ebay that might be worth the money, that one should be good quality I would think.
As far as the water pump, the only reason I wanted to add it is Dad just mentioned mowing with it does work it as 1st gear is to slow and 2nd is almost to fast, so it will boil over if you push it hard. So just thought maybe adding a water pump would remedy that and be better for the motor.
I plan to next spring to go through the tractor and flush the cooling system, and all fluids/oils in the tractor will get changed and things will get checked over good.
Then in between crops of hay or something I will jack it up and did into the front end with the advice you guys have sent my way. I appreciate all the info you have provided!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
