Re: 300 Utility fluid leak and transmission slip
Posted by big fred on August 27, 2000 at 11:25:29 from (208.51.245.60):
In Reply to: 300 Utility fluid leak and transmission slip posted by James Otoupal on August 26, 2000 at 17:43:14:
James, I would strongly recommend you get a operators manual. It will point out all the lubrication locations and tell you which lubricants to use. I would guess you have water in your transmission, there are three drain plugs (assuming you have torque amplifier and/or independent PTO). They are located right under the rear axle on the center of the tractor facing downward, at the very front of the transmission (just behind the joint between the transmission and clutch housing castings) facing forward, and about at the midpoint of the clutch housing facing downward. The transmission holds 7 gallons, so have at least 2 or 3 five gallon buckets ready. Fill with 90W thru the plug just beside the gearshift lever. Sounds like you also need to check your hydraulic fluid. The reservoir is under the seat, and there is a plug on top of the reservoir that has a dipstick attached to it. Use Hy-tran or similar fluid. The cap just in front of the hydraulic pump (by the distributor) is for motor oil.
Home
| Forums
Today's Featured Article -
A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
