Re: Hydraulic Filter 560 with 17 gpm pump????????????????...
Posted by bc on November 01, 2011 at 21:00:13 from (68.92.138.225):
In Reply to: Hydraulic Filter 560 with 17 gpm pump?????????????????????? posted by ralph1111 on November 01, 2011 at 20:15:42:
Both caseih and Oreillys (wix brand) has the high capacity filter. It is about an inch thicker. There was a guy around here who may have a listing on ebay who sells an extension to add to your cover plate to give room for the thicker filter. Around 40-50 bux as I recall. I'm not sure that it is an absolute that you need the thicker filter but it can't hurt. I believe I have the 17 gpm pump with the regular filter but I don't know without pulling it apart to look.
