Posted by CoopertownBob on November 01, 2011 at 22:35:19 from (74.51.5.116):
In Reply to: H Leaking OIl posted by John T on October 31, 2011 at 03:37:38:
Let us know how you make out. I just replaced mine today also, but I was doing all the seals in the rear frame as a matter of course since I had the entire tranny and final drive out and laying on the floor, replacing all bearings, (one was bad,) and various broken parts. The parts replaced list goes like this: Both bull pinions, the counter shaft seal cover and the entire center chunk! I pulled the front gear unit, after freeing the bolt you are having so much trouble with by putting it in third gear, fifth gear and reverse all at the same time, (I have the top cover off mine,) then putting a two foot breaker bar on that sucker! Then I took the entire unit over to my press and pressed the collar off its shaft, then pulled the three small bolts out and pulled the seal cover off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
