Re: Woods l59 on A
Posted by gene bender on November 02, 2011 at 07:01:08 from (67.55.226.244):
In Reply to: Re: Woods l59 on A posted by Russ from MN on November 01, 2011 at 20:33:38:
All you need to do to reverse the blades is reroute the belt on the center idler which will make blades rotate either right or left BUT that all depends on the spindles whether they are left or right ones. Threads are different.
