Re: 1947 Cub wiring
Posted by bmagee on November 02, 2011 at 07:37:47 from (66.162.122.135):
In Reply to: 1947 Cub wiring posted by bmagee on November 02, 2011 at 05:10:21:
Gene,
What I have is this:
one side of amp gauge is wire to the starter lug
other side has wire to light switch, one to BAT on VR, and one to ignition switch
wire from VR to F lug on gen
wire from VR to A lug on gen
thats pretty much it. If I take the wire off the from amp gauge to starter off, I can then put the ground cable on.
