Re: compairing old C pulley to new one/ fan adjuster
Posted by old on November 02, 2011 at 08:36:16 from (209.86.226.57):
In Reply to: Re: compairing old C pulley to new one/ fan adjuster posted by soundguy on November 02, 2011 at 04:33:43:
If the insdie of the new pulley has paint on it you may want to remove as much of that paint as you can. I know you would think that little bit of paint would not matter but I learned it does and also if it has some sort of paper tag etc that would run in the seal area remove it. I learned that a paper tag will make a seal leak. Had that problem on an Oliver 77 and the new pulley had a tag on it but I did not remove the tag and the new seal leaks badly till I removed the tag off the pulley and till I cleaned the paint out of the pulley it would not slide on but it is also not a press fit pulley
