Re: shutting off an A
Posted by Bob on November 02, 2011 at 08:49:36 from (64.255.159.192):
In Reply to: shutting of an A posted by charlie M on November 02, 2011 at 08:45:30:
That terminal is actually the NUT making the connection between the points, coil, and condenser... shorting that brass nut to ground SHOULD "kill" it!
