Re: BN fornt bolster oil or grease
Posted by gene bender on November 02, 2011 at 12:21:28 from (67.55.226.244):
In Reply to: BN fornt bolster oil or grease posted by gregnnerk on November 02, 2011 at 11:23:36:
I have rebuilt several and unless you have replaced the out-put seal yours will probably not hold 90wt as thats what was there originaly. Some use cornhead grease. But for the top bearing and the worm on the gear to work well 90wt is the best. Not that hard to rebuild just remove the assy by removing the 4 bolts at the bottom of the sector and the whole assy will drop down.Remove the pedestal first.
