International FBB298 Engine Magneto Timing
Posted by schultz on November 02, 2011 at 13:32:39 from (68.72.250.165):
This engine is out of a TA-40 Crawler or a W-40. It's currently on a run stand and I'm trying to set the ignition timing. It has a mag with an impulse coupling. I'm looking for a procedure to get me real close. Where should the engine be, TDC or 10 or so degrees before? Where should the magneto be before I try to line the plate up, with respect to the impulse coupling? I'm a distributor guy and the only other mags I've ever played with were automotive racing mags that didn't have impulse couplings.
Thanks,
